- 23 Jan 2007
- Wakefield
I was checking a few things over on my PC last night and noticed that there doesn't seem to be much air moving through my top rad. It's a Nexxxos XT45 with 3 SP120 quiet editions. Even running at full speed (1,400rpm) the scientific test of putting your hand below doesn't seem to yield much air flow. If you put your hand on the other side there seems to be losts of turbulence, like the air is just boucing back and not actually going through. Now I've checked the fans and they are mounted the right way round, I've checked the rad and there are no blockages, this was with the side of the case off so no positive pressure build up. The front 280 is totally fine and there is loads of air moving through it.
Is this normal, a side effect of the XT45 or I'm losing my mind?
