AirPods Max 2 sound interference
28 Jan 2011
hey guys,
I have had this before on my AirPods 4 ANC, and now on my AirPods Max 2 when using MacOS. It cuts sound sometime and also crackling...
firmware and software all up to date on both the MBP and the M4 MM?
cheers!
I don't suppose you're using SoundSource, are you?
I've noticed that both with my AirPod Pro 2 and my AirPod Max 2, if I'm using SoundSource and, for instance, have a YouTube video playing and then scroll through Reddit and a video auto-loads (even though the sound is muted on the Reddit video), it causes some sort of interference with SoundSource.
When I quit SoundSource and do the same thing, there are no issues.
I use SoundSource and have the same problem. Had an email from the devs saying that version 7 is in beta at the moment which hopefully fixes it.
Heads up that Sound Source 6.1 is out:
Several enhancements have been made for Bluetooth devices.
  • Multiple changes have been made to reduce glitches and dropouts.
  • Device iconography has been updated for several Apple and Beats devices, including AirPods 4 (with ANC), and Beats Pill.
  • Unnecessary drift correction is no longer applied to Bluetooth devices, resulting in fewer glitches.
  • SoundSource now only shows Bluetooth devices that are either already connected, or available to be connected to, rather than all paired devices.
Enhancements have been made for AirPlay devices:
  • AirPlay devices re-connect more reliably after waking the Mac from sleep, as well as on launch of SoundSource.
  • SoundSource now automatically reconnects to AirPlay devices when network topology changes, such as those which occur when connecting to a VPN, are detected.
  • AirPlay device audio-visual sync has been improved.
Seems to have solved my Reddit/YouTube issue. Hopefully, it fixes any problems you've been having.
