Yup, that looks like one, it has a female 3 pin connector so is the right one.benjo said:Hi, thanks for the replies.
I just had a scout on overclockers, isn't this what i'm after?
No, that is not the correct adaptor.benjo said:Hi, thanks for the replies.
I think they're just coloured differently, look at the placing of the wires in the akasa picture and in yours.Joe42 said:No, that is not the correct adaptor.
See it only has two wires, one black, one yellow?
Its to allow rpm sensing on fans with only a molex connector. It will not allow you to control the fan in any way. The adaptor you want needs to have a red and black wire to the molex plugs.
This is it:
Akasa Website said:Akasa cable adapter allows you to connect a fan with a 4-pin connector to a fan control unit with 3-pin connection.
Never said this before but i think this calls for it.....Owned?Joe42 said:Nope, i have several of the Akasa ones that came with fans, they do not allow fan control, only rpm sensing.
Yellow is rpm, black negative and red positive.
Edit: Just had a look at one of mine, your right sorry. It looks the same but there is a gap between the yellow and black cables.
Hey it was a valid point and a very easy mistake to make, the two adaptors look very similar, both made by akasa, both with 1 yellow and one black cable, but the ones i have here don't allow fan speed control.mark1 said:Never said this before but i think this calls for it.....Owned?![]()
I was just playing around mateJoe42 said:Hey it was a valid point and a very easy mistake to make, the two adaptors look very similar, both made by akasa, both with 1 yellow and one black cable, but the ones i have here don't allow fan speed control.
All the ones at overclockers are lacking is the speed sensor wire. I'm guessing what you mean is that your cables have a separate 3 pin connector for plugging into the mobo?james32 said:i got 2 with my thermaltake hardcano 13 fan controller
they also have the yellow rpm
the ones on overclockers are not the correct ones, dont look
like the ones i have
mine has black wire to black wire yellow wire to red wire on the molex
normal 3 pin, then the speed sensor is a female 3 pin.
ill try get photo, my memory card is goosed somehow.
