Akasa Apache - PWM?
With the akasa splitter, you can use 3 PWM fans, ive got one powering two vipers on a cpu cooler, also used it on a previous rig with 3 pwm fans (2 on a cooler, 1 rear exhaust), simply connect the 4 pin molex connector to the psu then add the fans and connect the mobo header to the boards cpu fan mount
cool ok.
Although, I've just tried it again in SYS_FAN2, and out of the blue it has decided to work :cool: :confused:
I'll probably order that cable if I decide to get another Apache.
PWM is 4 pin, but should be able to plug into a 3 pin connection as long as there is space on the side. My apache works in my 3 pin connections OK as far as I'm aware.
Ha a few weeks ago I had to smash up the PWM pin/part of the plastic cause there's something in the way (all other headers too) and I was angry!
