Akasa Zen Modding help :)
16 Jun 2007
London
Hello. i have an Akasa Zen, and want a Antec 1200, but i though ill save the money and mod.
ATM, i have nothing, so will need your help on tools, and how to mods etc
ok so, i want a window, black interior (from the original no window and steel interior) and i want to mod the mobo tray so i can increase cable management.
the front fan is essentially closed off to fresh air, so i want to mod the front to open a hole where it is. this will mean i have to cut out the buttons (power and reset) and the HDD light and power light. i will then need extenders for thier wires to the mobo, and buttons for reset and power.
i have 3 DVD drives free, so would like to mod them to stick in a fan there, and wind tunnel it with another fan at the end of the dvd drive cages.
also, then im sure i would need an outtake fan at the top, next to the PSU, do id need that aswell.
how much would i be looking to spend for tools pain fan (quiet ones) ETC.
and where would i get them from, i have a close BNQ and halfords. hopefully everything under £50?
Window* / Mobo tray / Fan holes = Drill (£15 B&Q) + Jigsaw (£9.50 B&Q)
Button holes / Tidying,Smoothing = Dremel ( Multi tool ) ( £20 - £50 )
Painting/Spraying = Primer/Paint/Wet and dry etc. (£3/can ~ £15 ( 1 primer,2 paint + paper)
*Window = Acrylic or Mesh Sheet £15-£20 , Edging £5
I make that a minimum of £80 ( cheapest tools ) without really thinking.
There will always be forgotten "bits" along the way = £10
So closer to £100.
Antec Twelve Hundred Ultimate Gaming Case = £112.79 inc VAT
DIY is not cheap to start with ;)
Mark
