One of the pads on my headphones has started to have the synthentic leather flake off in certain places. The pads can apparently be replaced, but I can't find any. I know they are a cheap headphone, but I found cheap pads for the Sony pulse ps3 headset and even pads for my old cheap panasonic htx7 , but nothing for these.
They are only cheap, but the pads for the others were only £10 or so and I see plenty of generic Xmm pads for similar sort of prices (£10), so If I could replace the pads for about £10, I'd do it, but I don't see any. Do I just need to go with a set of generic fits Xmm headphones & does anyone know the size for them?
If too expensive, I'll just leave it be, but generic replacements for other cheaper headphones were easy to find.
Thanks.
Thanks.
. Size I think they are approx 100mm outer and 55mm inner as that's what a few of sellers claim and seems about right from measuring my orignals.
