This includes newer ATI cards - http://translate.google.de/translat...ikkarten-im-Benchmark-Test/Action-Spiel/Test/
Older drivers though, 8.93 is Cat 12.1.
The 7950/70 drivers arent unified yet, also looking at the release dates they are the same, also they only test the 6990/GTX590 with the updated CAP3/FEAR2 profile, the rest of the results are using 12.1
12.1 - 1/25/2012 - http://support.amd.com/us/kbarticles/Pages/AMDCatalystSoftwareSuiteVersion121.aspx
8.921.2 RC11 - 1/25/2012 - http://support.amd.com/us/kbarticles/Pages/RC11Driver.aspx
I dont know it the CAP3 updates affect the 7950/70 or not?
Yeah, but from reading your link all they done is test using the same 12.1 driver as the link I provided, then done a small update using CAP3 drivers on the dual GPU 6990 card, and used a SLI profile from another game for the GTX590, all that shows is the multi GPU setups scaled poorly before, the single GPU results are both done on the same 12.1 driver.
So its not really newer is it?
It does not say in the bench you posted that they are using 12.1.
The 8.921.2 RC11 AMD Radeon™ HD 7900 driver still works on the other cards.
But as the drivers are not unified they must be using something other than 8.921.2 RC11 for the other cards tested, and the date of the test would show it was performed after the 12.1 were released.
these drivers work on 69xx series also if anyone was wondering.
