Hi all,
I've not found any reviews of the new Alienware's (believe they have just been released?).
There are a few about youtube talking about the MSI GS65 and Gigabyte Auro 15x, so I was wondering what you all thought about how the Alienware compares? Initially I never thought of them because (for some reason) I thought they had poor battery life (I take the laptop around for films and things while Im away), but just noticed its a 99wh battery, which is actually bigger than the others. But runs g-sync, which makes it worse? Possibly? The GTX1070 isn't MaxQ and is apparently overclocked (to unknown amounts). So performance should be better than either of the others.
Comparing prices, I can get an Alienware 15" with 32gb, 512ssd, i7-8750H, GTX1070 8gb OC, for 2200 GBP (my current MSI doesnt have a pound button on the keyboard, actually incredibly annoying).
Or all the above, but an i9-8950HK for 2500 GBP.
MSI GS65, with the above i7, MaxQ 1070, 512SSD, 144hz screen for 2400 GBP (which is pricey I thought).
Or
Gigabyte Aero 15x, exactly the same as the MSI but 16GB RAM from here for 2200 GBP (seems a much better deal than the MSI)
The only downside I can see is a slightly lower spec screen (120hz vs 144), but is this going to be much of a difference? And *possibly* less battery life. ALso for nearly the same price as the MSI I could get an i9 (future proof).
Im assuming it will be a long time before the next gen Nvidia comes out for laptops so no point in waiting?
Any thoughts?
Thanks
Or
Any thoughts?
Thanks
