????Are external switches.
I figured i would have to have a router/wifi and switch seperate. Are external switches. As i want to run cables outside.
I still don’t think what you are looking to do is a good idea, but here are options out there. If you are worried about running multiple cables through holes in the wall do bear in mind that you can get multi-channel Ethernet cables that have two or 4 Ethernet cables in one slightly bigger cable.
You’re enabling someone who clearly doesn’t grasp what he’s doing, let alone why it’s a bad idea, to do something that has ‘car crash’ written all over it. Just because you can, doesn’t always mean you should.
Op, you don’t need to run 8/16 cables through the same ‘hole’, you need a single feed to each location (eg room), the route you take is up to you, but remember with a single feed if you need multiple devices you can add a switch on the end of the feed. The down side of this is that the single link will be limited to symmetrical gigabit, in practice anything going from one device to another on the same switch won’t touch that link and realistically I can’t think of that many (likely) scenarios in a home environment where it would be an issue, most usage scenarios are more likely to be WAN limited.
That’s a bit condescending, don’t you think? If someone asks a question, are you not going to answer because you wouldn’t do it personally? These IP68 switches are designed to be used outdoors. If the OP wants to mount them outdoors then they’ll be fine. I wouldn’t do it, you wouldn’t do it, but that doesn’t mean it’s wrong. It just makes it unconventional.
Im here to learn as my knowledge of networks is limited, the reason i want to run cables outside is because i use a wheelchair and i cant get upstairs to lift floorboards so its much easiier for me to run them outside. If I could get a all in one wifi, router, switch i would but i still have to get 8-16 cables through wall.
