Kabaala said:Although i'm a bit confused after reading a chart on another forum earlier that had some people on it with over 3Ghz using the 6300 and the P5W![]()
Kabaala said:Thats what i get for having history disabled![]()
), I believe the max FSB of this board is 450, so you are looking at circa 3.15GHz theoretical max.....it has been said that Clockgen will get it to 500 FSB (3.5GHz), but the issue is likely to be the Northbridge stability at such high FSB speeds....
