Alphacool Eisbaer Extreme vs EK-MLC Phoenix 280
5 Nov 2010
Hertfordshire
Hi all,
Looking towards the high end of an upgradable AIO solution to cool a 3900X and I think i've narrowed it down to:
or
EK-MLC Phoenix 280
Similar pricing, so down to performance. Leaning towards the EK-MLC Phoenix.
Anybody have or know of these two to weigh in their opinion/findings?
TIA
20 Apr 2004
London
Are you just doing the CPU or the GPU too?
Was just taking a look at the configurator. Interesting how you can only choose only 1 280 rad for both CPU / GPU.
Looks good though, i was in two mind of downgrading my custom loop purely because it is a hassle everytime you want to change anything.
OP
5 Nov 2010
Hertfordshire
Just CPU for now, but GPU later on.
You could add multiple rads in theory, but I believe there's a 360 coming soon.
20 Apr 2004
London
There was a 360 but its now end of life... hmmm.
Why not go down the standard cpu AIO and then a separate AIO for the GPU, so essentially two AIOs
9 Sep 2013
Carmarthenshire
I Have the MLC-Phoenix, I actually have 2 closed loops.
1 x 360 for the 1080 Ti
1 x 240 for the 9600K
I also had the Predator series before the Phoenix.
Great products, never had any problems with any of them.
I game at 2560 x1440, my GPU temp never goes above 50oc.
I'm not sure if this is of any use to you, but I thought I would post from
someone who actually has the products.
OP
5 Nov 2010
Hertfordshire
How long have you had them and have you needed to top them up yet?
What sort of performance are you seeing on the CPU?
3 Jul 2009
I have the Phoenix 280 myself, cooling both my cpu and gpu (2600x & 1070ti), id echo everything drex said really, not had to refill yet, but easy enough to do if needed. One thing to note especially if planning to use in a small case, the tubing length is longer then normal CLC's.
Temps wise i range from: CPU: 60-70c gaming, Gpu 40c - 50c game dependent (settings used) fans and pump both set to 50%. I went into it knowing my cpu temps would be slightly higher due to the fact both are on the same loop, but i'm good with that.
For more powerful cpu/gpu combo's then mine you may want to to do what Drex has done and run 2 seperate ones. A 280 can cool both, just don't expect temps to be brilliant is all.
