Alternative to Crucial Ballistix DDR2 PC2-6400C4 800MHz
26 Feb 2007
Leafy Cheshire
Hello. Me again.
I've got some of the afforementioned Ram (2x1gb) in my mobo, but it doesnt match well with the board itself. Its an Asus P5N32-E SLi Plus. The memory wont run at stock speeds and Asus and Crucial both tell me to change the board or ram.
If i was to swap the ram, which kit is most similar by another manufacturer? I would want the same quality and customer service (or close as possible). Would this be likely to work any better with the board?
Or should i change the board rather than the ram? hmmm.
hmm reckon i should chop in the board then?
Could pick up a second hand DS3 or P5N-E for reasonable amounts now
decided to go with the GA_P35C_DS3R i think, see if i can pick one up on the MM or bay. Should be able to flog my board for a similar price for minimal loss!
