Alternative to PC storage
26 Dec 2009
London
I've got 7HDDs and a SSD in my machine.
My plan is to eventually have a watercooling setup and the 750d with two rads cant hold all those.
How does adding these drives to another machine and accessing them through the network sound?
I use these regularly mostly to read from.
I have a HP Microserver which can take 4 disks. I know technically it can work but does it sound like a good alternative to having them in my main rig?
I have a network drive that I store quite a lot of my files on. Music, movie files (all my recordings) etc.
Transfer takes a bit more longer - but not too bad.
You'll want at least Gigabit Ethernet, or access will be painfully slow especially if transferring large files, but otherwise it shouldn't be an issue.
No reason why it would not work fine from your microserver either, as good an alternative to having them locally.
or just look at one of the 4 bay nas boxes, synology or qnap.
Yeah, I wont exactly be doing much transferring. Mostly reading from the drive and downloading to.
The microserver is gigabit networked.
So i was thinkng instead of having windows on disk i would have some kind of os on a usb. Any suggestions?
I'd always have an OS on a hard drive/SSD. You can set up linux to run via CD/USB - but I don't know how good it is for normal use.
Just taken a look at freenas, seems to be the one.
Can run on usb and access quite easily with local ip, map to windows network drive. I'm gona try that out.
Just as food for thought, when I move out I'm planning to build up a server running server 2012 R2 (on an old athlon 64 initially, could be fun!) with a small SSD for the OS, and 3 or 4 drives for media and backups. All will be gigabit networked, and built into my old midi tower case. Initially it will serve files and be a DLNA server, later down the line I may add capabilities.
Server 2012 is free through dreamspark if you're a student.
