Just back from Kwik-Fit after the third test. Failed on emissions test, got it sorted and took it back and they said it passed so then he goes away to do the paper work. Says your 10 days is up for the free re-test. Have to do a complete new test. All old faults fixed at this stage, but now they say the front (d / bush / marked) Anti-roll bar rubber mounting deteriorated resulting in excessive movement bot sides.
Front suspension has excessive movement at a wishbone pin or bush, both sides. How comes they find these new faults all of a sudden and not before. I ran around for days sorting all the problems out and now this!!!!!
They fixed this last year, ie front Anti-roll bar rubber bush deteriorated resulting in excessive movement, both sides.
Nearside front Anti-roll bar linkage rubber bush deteriorated resulting in excessive movement. I paid over £400 to do this, last year.
My invoice from last year:
QTA3078 Bora 2.0 99- FS £83.20 X 2 £166
SPEBSH-ROLL BAR BUSH £24 X 2 £48
SKIT119 ANTI ROLL BAR LINK £37 X 2 £74
GEOALIGN CHECK AND FRONT ADJ £45
GEORETOE REAR TOE ADJUST £20
GEORCAMB REAR CAMBER ADJUST £20
£405.
Have they pulled a fast one on me and taken me for another mug. What can I do, I have 10 days to sort it. I've paid them for 2 M.O.T's now and it should have been sorted earlier before the full new test because all faults are fixed.
£405.
