Am I being stupid?
21 May 2010
Digbeth
OK, so my SSD is running sweetly, but there seems to be about 100meg or so added everytime I look, what is this?
I am sure I turned indexing of, and how do I use TRIM, I don't even know where it is :/.
Could be temporary files, downloads, page file.
How to enable trim? Google is your friend, many results! I do not have a SSD to know off the top of my head.
TRIM is automatic under Windows 7 as long as your SSD supports it. Disable the things mentioned above (reduce frequency of recovery images and delete old ones), change page file to reside on a different (spinny) disc.
100mb each time you look? You'll have to give more information than that. Is the space usage increasing by 100mb each hour? Every week?
How do I do all of those? And 100Mb a day roughly...
thanks for the info......i just got back a hell of a lot of space on my 40 gig intel ssd.....ive disabled hibernation, reduced the pagefile to 4 gig and turned off windows restore........
Re: pagefile. There's not really a right answer for this, apart from 'it probably doesn't matter'.
It depends on who you ask. Microsoft recommend leaving the pagefile on the SSD (http://blogs.msdn.com/b/e7/archive/2009/05/05/support-and-q-a-for-solid-state-drives-and.aspx), OCZ and Corsair recommend you move it to a storage drive (http://blog.corsair.com/?p=3989).
Either way, the performance difference will be minimal, and it while *does* have an effect on SSD, this will be such a long term thing that it's not going to matter for anyone. Modern SSD's have very high resistance to performance degradation.
