Am I doing this right?
26 May 2009
Morning Mr Pack, if you have a sec could you please give these settings a once over and suggest improvements/tell me if I have done anything retarded :)
I'm running a 3820 @ 4.5 in a RIVG with Sammy Greens. Haven't put the RAM timings below as I'm tarded but their running at 2000MHz (9-10-10-28 1N) @ 1.45v and rampage tweak is at mode 1.
Extreme Tweaker Menu
Ai Overclock Tuner: Manual
CPU Level Up: Disabled
Bclk freq: 125.000
CPU Strap: 125MHz
ClockGen Full Reset: Enabled
Turbo Ratio: Disabled
By all cores : NA
CPU Clock Gen Filter: Auto
Memory Freq: DDR3-2000MHz
Extreme Tweaking: Enabled
EPU Power Saving Mode: Disabled
Extreme OV: Disabled
Bclk Skew: Auto
CPU Vcore : Manual Mode
CPU Vcore Voltage: 1.34
VTT CPU Voltage: Auto
2nd VTTCPU Voltage: Auto
CPU VCCSA Manual Voltage: 1.1
CPU PLL Voltage: 1.65
PCH Voltage: Auto
VTTDR Voltage (A, B): Auto
VTTDR Voltage (C, D): Auto
CPU Spread Spectrum: Disabled
PCIe Spread Spectrum: Disabled
Digi+ Power Control Submenu
CPU Load-Line Calibration(LLC): Medium
CPU current capability: 140%
CPU Voltage Freq: Auto
VRM Over Temperature Protection: Auto
CPU Power Duty Control: T.Probe
VCore MOS voltage Control: Auto
CPU Power Phase Control: Extreme
CPU Vcore Boot Up Voltage: Auto
VCCSA Load-Line Calibration(LLC): Auto
VCCSA Current Capability: 120%
VCCSA Fixed Freq: 300
CPU VCCSA Boot Up Voltage: Auto
CPU VTT Switching Freq: Auto
CPU VTT Over-Current Protection: Auto
DRAM-AB Current Capability: 100%
DRAM-AB Voltage Frequency: Auto
DRAM-AB Power Phase Control: Auto
DRAM-CD Current Capability: 100%
DRAM-CD Voltage Frequency: Auto
DRAM-CD Power Phase Control: Auto
PCH Switching Freq: Auto
CPU Performance Settings Submenu:
CPU Ratio: 36
Enhanced Intel Speedstep Technology: Enabled
Turbo mode: Disabled
Power Limit Control: Auto
Advanced Menu
CPU Configuration Submenu:
Intel Adaptive Thermal Monitor: Enabled
Hyper-threading: Enabled
Active Processor Cores: All
Limit CPUID Maximum:
Execute Disable Bit: Enabled
Hardware Prefetcher: Enabled
Adjacent Cache Line Prefetch: Enabled
DCU Streamer Prefetcher: Enabled
DCCU IP Prefetcher: Enabled
Intel Virtualization Tech: Enabled
CPU Power Management submenu
CPU Ratio: 36
CPU C1E: Enabled
CPU C3 Report: Enabled
CPU C6 Report: Enabled
CPU C7 Report: Enabled
Nothing looks scary there. I'd set your DRAM voltage if you haven't. My board loves to give everything way more voltage that needed.
Also your VSSCA LLC could be knocked down to regular to start with.
Looks fine to me. I would set VTT and VCCSA manually as this often gets over volted too high. So set both to 1.1v ish.
There may be more opportunity for improvement in RAM timings and perf. You tried 8-11-11 ??? Also by enabling Mode 2 this gives you a perf hike providing its stable. VDIMM I would set at 1,65v unless you care about electricity bills to the penny.
In RAM settings your seconds can go 5-128-auto-10-6-26-6-7. So initially try C8 1T and Tras 21 then what I suggest above for seconds.
Awesome, thanks man ill get the VTT/VCCSA set to manual and try tweaking the RAM timings more, I basically just copied the timings/voltage listed for 2000MHz off the OcUK product page.
Now clock it even more!
Hehe, I'll probably end up doing that sooner rather than later, never been the type to settle, I think my temps have some headroom, after an hour of Prime95 blend test my temps were 63c on the hottest core (or 62 according to HWmonitor) and under normal use the hottest core reached 53c during a long gaming session.
Plenty of head room. If you need loads more Vcore for the next multi dont bother with that just use BLK.
Its a silicon lottery!!! Some chips scale better than others!!! when your chip stops scaling linearly with volts then back off as that is your top clock without torturing it!!!
