am i dumb or ek instructions wrong??
25 Jun 2011
Aberdeen
Just fitting a d5 to an ek-d5 x res, the drawing shows it being fitted res>pump>oring>clamp plate. If I do it that way something is going to snap.
Now I found a video of the non csq res top being fitted and the guy went res>oring>pump>clamp plate, this way it fits perfectly though not leak tested.
So who's in the wrong here??
Yeah would be between the pump and res I would think, able to post a picture to be sure? Usually the o-ring sits in the groove round the edge off the pump body and between the top. Would think the res version would be the same.
it's just a confusing diagram that's all. They should have put arrows indicating to slide the O ring and the bottom of the block up to meet the top of the block. If you look at the pump you can see where the O ring sits. I would be inclined to remove the res, and lay the top of the pump top down, then put the O ring where it goes then the pump, then the bottom of the top, screw the screws in from corner to corner and then finally screw the res in.
