I have been wanting to get a new PC for a while, I am really close to ordering but I just had a feeling what I'm ordering is too much for what I'm going to use it for. The reason I'm upgrading is that I want to get a solid 100/150+ FPS on CS:S, as I only get around 60-70 with low settings and a modified config, and when I'm in deathmatches it can go as low as 10-15 due to all the action. I haven't overclocked before, but I might do a bit with stock cooling -- I don't really want to mess with water cooling, etc etc. My current system is:
GPU: 7600GT Palit AGP
CPU: AMD Athlon XP 2800+
Mobo: A7N8X-LA
Ram: DDR PC2700
Usage:
Games I would like to play but I can't on my current system:
The specs I chose were:
Intel Core 2 Duo E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail £121.99
(£143.34) £121.99
(£143.34)
OcUK GeForce 8800 GTS 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £154.99
(£182.11) £154.99
(£182.11)
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK) £61.99
(£72.84) £61.99
(£72.84)
Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM £44.99
(£52.86) £44.99
(£52.86)
Lian-Li PC-7 PLUS Aluminium Midi-Tower Case - Silver £45.99
(£54.04) £45.99
(£54.04)
Gigabyte GA_P35C_DS3R (Socket 775) PCI-Express DDR2 & DDR3 Motherboard £81.99
(£96.34) £81.99
(£96.34)
Corsair 2GB DDR2 XMS2-6400C5 TwinX (2x1GB) £51.99
(£61.09) £51.99
(£61.09)
Total : £675.48
I wanted the motherboard as it would be good for upgrading in the future and I wouldn't have to totally re-spec out again hopefully. I don't need a monitor/keyboard/mouse, and I'm going to use the CD drive from my old PC and I have a budget of £680 maximum - Any advice?
Mobo: A7N8X-LA
Ram: DDR PC2700
Usage:
- Counter-Strike 1.6 @ 640x480
- Counter-Strike: Source @ 800x600
- Sony Vegas/vdub rendering
- F.E.A.R @ 1024x768 (probably)
- World in Conflict
- And I might try out Crysis as it looks fun.
(£143.34) £121.99
(£143.34)
(£182.11) £154.99
(£182.11)
(£72.84) £61.99
(£72.84)
(£52.86) £44.99
(£52.86)
(£54.04) £45.99
(£54.04)
(£96.34) £81.99
(£96.34)
(£61.09) £51.99
(£61.09)
Total : £675.48
maybe I'm blind
