Hi all
Got round to fitting the GPU into the build and checked all the bits were fitted and as far as i know they are....... HOWEVER!!!
Plugged the PSU into the wall the front panel lit up so i press the power button.... Nothing!! The Stock Ryzen fan doesnt move and nothing happens
Checked:
The PSU plug is in properly
24 pin is seated properly
And as far as i know all other switches are seated fine
What can this be?
Thanks
Checked:
What can this be?
Thanks
