does this seem ok form a differnce between core 0 at 43 at idle and core 1 at 33 as i here from reading other threads with intel cores 5 degrees is about the tolerence does this same tollerence apply to am2 cpus, any one else have a 600 0 cpu with the same differences or please tell me what difefrence your cores are
In the past on my old 754 athlon 64s i removed the IHS and it did shave off around 7 degrees is it worth it on the am2s ? or is lapping a better solution or anything else to help save degrees ideas much appreciated.
measured with coretemp 0.95.4 as seen in thumbnail
see my other thread) , what u guys mean when you say reseat it , take it out change the thermal material generally tidy up. does lapping or ihs removal make any difference on am2 ? never tried it on am2? cause my chips the oem so only got a years warantee too void anyway
