Hi all
Bonus time has arrived, so just looking at a new system. My old rig is Socket 754 + AGP, so its pretty much an entire new system I need.
Am tempted to go with an AM2 x2 based system (not FX-6x) on an MSI K9 mobo, and I wont be overclocking anything (well, not by much anyway ). Any recommendations for a 1Gb or 2Gb  choice?
(I dont see any DDR2 800 options on OcUK, the DDR2 667 will slow things down I think, and the DDR2 1066+ are expensive and would be underclocked on this system anyway)
<devils advocate>
Or should I just wait for Conroe?
</devils advocate>
Thanks for you help, it is appreciated.
Z
 ). Any recommendations for a 1Gb or 2Gb  choice?(I dont see any DDR2 800 options on OcUK, the DDR2 667 will slow things down I think, and the DDR2 1066+ are expensive and would be underclocked on this system anyway)
<devils advocate>
</devils advocate>
Z
