Hey guys,
Wondering what's the best option here.
1). Coolermaster Hyper 212 Plus (for £14.99 inc.)
2). Gelid Tranquillo (for £25.99 inc.)
3). Thermolab Baram (sans fans) (for £20 2nd hand.)
I'll also need to get some TIM remover (don't really want to use nail varnish remover
) which is around £5 iirc.
Budget is pretty much anything, but obviously I want to spend as little as possible.
Will be cooling a 955BE @ 4.0GHz (1.4v at the most) in a CM Elite 330 case (yes, meagre two 120mm fans).
From reviews I've read the Tranquillo is about 1'c cooler than the Hyper 212+ (but reviews I've found are only on a 920 D0) and from a members experience (MOOGLEYS) it runs his 955BE (same stepping as mine) at 58'c.
Which is the best option,
Cheers guys!
Alistair
) which is around £5 iirc.Budget is pretty much anything, but obviously I want to spend as little as possible.
Cheers guys!
Alistair
