- 3 Jul 2007
- Newcastle UK
My dads just recently bought a laptop making his desktop pc redundant.
Decided today that i could utilise it and swapped my GPU and PSU into it.
Marginal increase in ram and CPU performance was the reasoning.
Been gaming on it tonight and one of the fans has been going crazy.
After taking the panel off its the CPU Fan, so im thinking that perhaps the stock one isnt up to the job. My dads never gamed, so i doubt this will have ever been an issue for him.
Im not planning on overclocking, so just want something more effective than stock.
Spec
Amd Phenom II x4 955 Black edition
4gb DDR3
Asus M4A785TD-VEVO
Corsair HX520W
Sapphire 512mb HD4870
Coolermaster elite 335.
Firstly what temps are acceptable for CPU and GPU units?
Recommend me an aftermarket cooler please. If buying a new one, will i need to re-apply thermal paste? Or do they come with some.
The case has a ported funnel design on the side which sits fairly close over the cpu fan. Should i maybe be looking at an additional fan to blow or extract some air out/in? through it?
Thanks for your feedback
Spec
4gb DDR3
Asus M4A785TD-VEVO
Corsair HX520W
