AM5 upgrade...
16 Feb 2006
So I've managed to get a 4080 for free (won it) so I thinking if I sell my am4 kit and gpu I can fund a 7800x3d upgrade but its still quite early in the AM5 lifespan....is jumping up a good idea or should I hold off?
I made the switch from AM4 to AM5, there's still a few bugs to iron out, but there was with AM4 in the beginning too, I don't regret it, it is noticeabley faster than AM4, once I'm through post my pc boots in about 6 seconds to the windows lock screen, and as usual, AMD will support the socket for a few generations, so you'll only have to change the chip later down the line if you want to upgrade, unlike intel who change the socket every 2 generations, even by 1 pin, that's what made me switch to team red to start with.
I was thinking of going Intel this time but decided to go AM5 for the drop in upgrade in a few years. It’s a difficult choice as performance is almost the same, Intel win some and AMD win others. Been using AM5 for ~5 months and not had any issues yet. I don’t know if I would recommend buying any hardware now, Manufacturers are doing some messed up ****.
What your system spec ?
5800x, 3070, 32gb ram @ 3800mhz cl16 tightened right up.
I would never have considered it but with getting the 4080 for nothing, I thought I would buy a 5800x3d with the money from the 3070....but then if I sold the rest of my set up I could probably go 7800x3d and only have to spend £150-200... There's no way I'll be able to get off am4 if I don't do it now I feel given the situation Ive found myself in.
I'd say go for 7800x3d if you only need cpu/memory/mobo.
The expo 6000 cl30 kits are pretty cheap at £130 and £180 b650 mobo is more than enough.
£440 + £130 + £180 = £750
I'd say you might get £550 for your parts.
For £200 thats a pretty big upgrade.
going 5800x3d will prob bank £100 or so as selling gpu will prob cover the cpu, so what ever you make on the 5800x you're in the black
Well you been given an opportunity to upgrade and if you think it's worth it , why not .
I'm not seeing CL30 kits for £130, probably need to look harder :cry:
Just make sure to update the bios asap if u do go for am5 and that cpu. As it might ship with a old bios like gamers nexus has said.
Yeah thankfully I don't care about RGB so got g.skill trident neo z5 6000mhz cl30 after I spotted the price had dropped this morning so 7800x3d and b650e has been ordered as well.
It was now or never really, I don't like jumping in early to newer tech but the chance has happened so I'm going in!
Agreed, I decided it was nearly as cheap to build an AM5 system, and move my AM4 down to office work, as it was it buy something to do office tasks.
