Hi got the above CPU and been playing with the overclocking
1st timer for overclocking.
I have gone into bios and changed the memory to 200mhz and increased the HTT/FSB to 215 approz and pc started 1st time with new cpu at 2.380mhz.
Is it that easy ? I know ablout the heat and im running a stock cooler so will keep an eye on that. Should I just keep increasing the HTT/FSB till it bombs out?
Any other suggestions as it seemed so easy.
thanks
1st timer for overclocking.I have gone into bios and changed the memory to 200mhz and increased the HTT/FSB to 215 approz and pc started 1st time with new cpu at 2.380mhz.
thanks
