Well from my limited experience of it the on-die thermal diode gives a good indication if too high a CPU temp is what's causing Prime95 to fail or the system to freeze or crash while stress testing.
You mentioned previously your current setup failed Prime95 after a few hours and if you check Next Sensor you might find the on-die thermal diode is actually reporting a temp that highlights why it's failing ie the actual temp of the CPU is too hot but you can't really know that by relying on the motherboard reported CPU temp as 49c isn't really too hot.
So yeah check the on-die thermal diode via Next Sensor please mate.
