This is my sons computer, getting on a bit now but its still up the the task and runs all games. Cards an Asus reference design, hitting around 100c under load, max temp ive seen it hit is 103c. The card would always run around 70-80c gaming, up until recently and i noticed it was a lot louder than normal, (gpu fan working hard) checked the temps with afterburner and they're the readings i got.
Ive had the cooler off and gave it a good clean and new thermal paste which has not made the slightest bit of difference. Side panel of the case off and 15 inch fan blowing into it has brought temps down a bit to mid 90s, but still not good.
About a month ago his psu went pop tripping the main electrics in the process, lian li maxima force 650w around a year old, beware of that psu. Brought him a new psu (xfx 650w xxx) as its the same psu ive used for around 3+ years going strong and thinking about it it seems this has been happening since then his psu went bang.
So im wondering is it possible that the cards been damaged in some way caused be the psu going bang?
Any help would be much appreciated.
