Caporegime
- 18 Oct 2002
That is certainly a possibility and with 128GB NVME drives coming in at about £60, 32GB of flash shouldn't add too much to the cost of a graphics card.
Definitely interesting times ahead.
Problem there is internally ssd controllers treat the NAND chips in raid which is why a 256GB stick is much faster than a 128GB stick(more so in writes than reads with those capacities). A 32GB stick would have so much less performance for read as well as write and a lot less utility in terms of wear levelling/life span, that it's not really feasible. Remember that they managed 850MB/s over the normal pci-e bus M2 storage, so a 32GB NVME stick that only had 300MB/s of reads wouldn't improve things. THen in price terms if you're using the same £20 pcb/controller/vrm regardless of if you use 1 Nand chip or 4, price doesn't come down as much as you think for such a low capacity anyway.
Maybe AMD is already cooking something up? Might explain why they not jumping onto the highend GPU market this year. Would love to see this used on Desktop GPUs can see it helping out in high demanding situations.
Cooking something up, sure, it's called Navi with 'nextgen memory'. That nextgen memory is 3d Xpoint memory. 3d xpoint is pretty much a game changer when it comes to density of memory and speed, which sits somewhere in the middle of Nand and RAM.
My guess is Radeon Pro SSG is more aimed at getting the industry prepared for Navi with a half way step, show them what can be achieved with two ssds on the pcb, tell them(under NDA) that Xpoint is coming that will offer higher capacity and more speed in the same size and they buy the Pro SSG to both use but also start moving their software to be optimised for that and ready for Navi.
The question would be, with Xpoint being faster per chip by a good deal than NAND and much lower latency(further increasing the bonus of being on the pcb rather than going through pci-e bus, driver, cpu and back through all of them again), will there be a benefit for gamers with lower capacity.
Release a high end Navi with a $15k 1TB xpoint version for professional and a $600 version with a single 32-64GB chip for gaming.
