- 3 Feb 2009
So I have a htpc type setup running on an old A8 6500t that I'm looking to upgrade due to wanting h.265 playback without having to install a dedicated GPU.
The intel site is pretty clear with what igpu's can do that but I can't find anything equivalent for the AMD side of things. Essentially, I'm just looking for the cheapest/lowest power chip that will achieve the goal, which means 7th gen intel and the associated upgrade to ddr4 which isn't a particularly cheap looking option.
Is there an AMD alternative?
