- 17 Sep 2003
- Suffolk
Hello All,
I've recently put together something I've been meaning to do for ages which consists of:
Asus M4A79XTD Evo Motherboard (http://www.overclockers.co.uk/showproduct.php?prodid=MB-366-AS&groupid=701&catid=5&subcat=1481)
6x Samsung SpinPoint F2 EcoGreen 1.5TB (http://www.overclockers.co.uk/showproduct.php?prodid=HD-080-SA&groupid=701&catid=14&subcat=1279)
I've set them up in Raid 5 but I'm unsure if the performance I'm experiencing is as good as I should be.
I left all the raid settings as default and I'm not sure if this was the right thing to do, the Stripe is set to 64k and I've checked that the write cache is enabled.
I've copied a bit of data to it already but if recreating it with a larger stripe is going to see a worthwhile increase in performance then I would be happy to do that.
When copying to it its about 50 MB/ sec which is not too bad but I was hoping from my Samsung F1 1TB it would be a bit higher... am I expecting too much?
Any ideas?
Thanks,
Michael
Any ideas?
Thanks,
Michael
