The problem that this solves is by removing the GPU thermals and placing it outside the laptop, you would (in theory) get a quieter and also much more GPU power than you would be using a Alienware 17 type solution where you have masses of heat build-up.
It also gives Apple the chance to remove the DGPU on the upcoming Macbook pro refresh. It is possible that the macbook pro 15 will use IGPU only and offer the X-Connect as an option.
The prototype X-connect box i saw would easily fit into a laptop bag. Polaris makes this a very exciting development for those of us on the road and need to stay mobile.
No, I won't use it on the plane or train however, in the hotel room or family house it is a breath of fresh air.
AMD might do what they did with Freesync and try to make it a non-royalty open standard. The current situation with no standard is not great even if Nvidia go their own way.
So does a Macbook Pro 15 with a Polaris X-connect appeal? Yep, I'd buy that for a dollar. Let's see what happens in June at Computex.
