Actually, speed is relevant as it also relates to latency. Whilst slow wide ram will have the same throughput as thin fast ram, if you have less data to process as with 1080p vs higher resolutions, the bus width is less of an advantage, so processing thinner widths faster means your actual latency and throughput is better with the faster ram.
With memory running at 500mhz, each access takes a minimum of 2ms... With memory running at 6000mhz each access takes 0.16ms, so yeah where you need high throughput they even out, but at lower throughput levels gddr has a clear advantage.
This is likely why AMD talk about better memory management being needed with hbm, as they need to rework the memory loads to try to maximise the data being read each pass and minimise the number of calls
