Hi people! I received my 4400+ from OCUK yesterday and have been playin around with overclocking it. I have ir currently running at prime stable with the cores at 2.5Ghz each. My problem is i don't know if the temp readings i am getting are correct. I'm using a Freezer 64 pro from arctic cooling and, since i know the temp sensors on the dfi expert are known to be a bit dodgy, i downloaded a prog called Core Temp that was recommended throught he DFI forums. Thing is its showing some pretty strange readings. Core 1 is reading as 59C under load which i think is on the high side when core 2 is reading 44C, which is more like what i was expecting. Does anyone else have any experience with this prog? or such a large dif between their core temps? I have about 1.42v going through the core at the moment but that should whack the temp up to almost 60C should it?!? Any help will be appreciated!
Looks like your chips are running soo much hotter than my 3800 with 1.55, is it the extra cache?
Hi, Im using a 64 x2 4400 and my temps read 32 idle and around 42 under full load with the Gigabyte G-Power pro.
