Hi all,
If all goes well I will be upgrading very soon, my 128gig M225 has arrived and my sata2 raptor is on it's way, I'm running an abit IX38quad gt and wonder if I should run the m225 and raptor in AHCI, any benefits??
I will be installing Win7 32bit as part of the upgrade..
Many thanks, T Box
Many thanks, T Box
As long as you use the native MS driver then TRIM should be supported providing the M225 is running firmware revision 1819, the current Intel (I'm assuming it's an Intel chipset) drivers don't support and pass through the TRIM commands from Windows 7 to the drive.
