An Unexpected Error Problem with Network connection
19 Oct 2002
Bath
Right guys every time i try to click properties on my network connections status page i get this error
I have tried the solution provided by Microsoft and it has made no difference.
I have also tried running sfc /scannow but that gives an error too
Anyone got an idea
Start > Run >
Type "regsvr32 netshell.dll", and click OK in the dialog that comes up
Type "regsvr32 ole32.dll", and click OK in the dialog that comes up
Reboot.
Check.
In safe mode i am unable to remove the adapter it says Access Denied because the adapter is needed to boot the computer. And now rebooting in to normal session of XP i cannot use the adapter apparently there is a problem and it is unable to use the device.
The Desktop Pic is from the Desktops Thread and i dule boot Ubuntu and XP Pro for support calls to end users and gaming as Ubuntu dosent like new games much. :)
never used it as it only takes 2hrs to reinstall completely as i have just done.
Thanks for your ideas guys but im all back up and running again now :)
Obvesouly something was corrupt, you could have used an image ;) 6 minuits to restore even with updates, patches, hotfixes e.t.c :D
nearly finished sorting it all out now so will crank up Acronis True Image (have owned it for ages but never used it:))when im done and creat an image. Have been meaning to do it for ages :(
You will regret not using an imaging program from the day you started pcs!! True software to computers.
