We're still early in the release cycle for Civilization: Beyond Earth – in fact, our testing was done with pre-launch code, and there's already talk of a day zero patch to fix a few glitches (e.g. with multi-GPU configurations that have more than two GPUs) – so by no means is this the final word in performance. It's not too surprising to see NVIDIA's GTX 980 taking the single GPU performance crown for Beyond Earth, but additional driver tuning may change things a bit. The good news is that if you have any reasonably modern GPU – from the GTX 770 and R9 280 (nee HD 7950) – you should be able to run at 1080p and High or even Ultra quality settings. Lesser GPUs can still handle the game as well, and if you're curious it's possible to get frame rates well over 100 FPS even at 1080p if you drop to lower quality settings.
As for Mantle, it remains an interesting option if you have an AMD card, but so far we haven't really seen a huge benefit. I suspect if I were to retest everything with an AMD APU or a Core i3 processor, Mantle might prove more efficacious, but even with price cuts I don't think most gamers are going to spend hundreds of dollars on a fast GPU only to pair it with a slower CPU. Mantle is also proving to be a challenge when it comes to multi-GPU configurations; optimizing for SLI and CrossFire often requires a bit of extra work, but adding Mantle into the mix further complicates matters. I'd love to see Firaxis really tune their Mantle code to get SFR running at better than AFR frame rates, but that's asking a lot and frankly I'll believe it when I see it.
{gallery 4008}
As far as the game itself is concerned, Civilization: Beyond Earth looks like it may prove every bit as addictive as the earlier releases. Now that I've done a ton of benchmarking with Civilization: Beyond Earth, I need to find some time to actually play the game. My birthday is coming up next week, so maybe I can get some free time as a present…. Then again, birthdays only last 24 hours and if past experience is any indication, I might need more like a month to get Civilization Fever out of my system.![]()
http://anandtech.com/show/8640/benchmarked-civilization-beyond-earth
