Caporegime
- 18 Sep 2009
- Dormanstown.
Anyone got any end game benchmarks? The initial results are pretty meh for mantle as far as I'm concerned.
Here's an interesting fact that anandtech didn't touch on. Mantle actually uses a higher quality AA pass, so they have improved AA vs alternatives. This has a higher performance cost, but thanks to Mantle Radeons are able to remain competitive and in some cases faster. You really get the best of both worlds. DirectX uses MSAA and AMD's Mantle uses EQAA. Quite impressive when you look at the performance numbers.![]()
That is interesting Matt, I do hope you can turn off this feature though, as we do not want to have a situation where any benchmarks that use Mantle are actually running different settings than everything else making them useless in an apples to apples comparison.
It can't be disabled Bru, however you can lower the quality of it if needed. This was the decision of the developer to give Mantle the 'edge' in this game. It will have all the things you can expect of Mantle though, smoother performance, more consistent frame times and variance and in this case, superior AA quality which does cost more performance than MSAA. The fact it's able to remain competitive (and in some cases faster) speaks volumes though.
Yes it does remain competitive which at the moment is good.
I just hope that it doesn't become an excuse latter down the line 'if' things move around to allow Nvidia pull ahead by some margin.
I can see it now 'Well if mantle wasn't doing better AA it would be faster.....bleat bleat bleat'![]()
One of the interesting aspects with Civilization: Beyond Earth is that the developers, Firaxis, have opted to include support for AMD's Mantle API. We've been over this subject quite a few times, but the core idea is that Mantle provides low level access to the graphics hardware, potentially allowing for improved performance or other improvements. We've seen other games use Mantle (Battlefield 4, Thief, Plants vs. Zombies: Garden Warfare, and Sniper Elite 3), but this is the first game to really do something more with Mantle than reducing the cost of draw calls. That's still a benefit that Civilization: Beyond Earth enjoys, but Firaxis has gone a step further for owners of CrossFire setups and has enabled a custom Split-Frame Rendering (SFR) approach for multiple GPUs instead of the typical Alternate-Frame Rendering (AFR) that most games use with CrossFire and SLI. I like the idea of SFR, as it means adding multiple GPUs won't increase input latency, but it can be far more complex to implement (which is why most games choose to go with AFR).
So is EQAA the same as nvidia CSAA ?
looks very similar in terms of what it does.
It is.
Maybe the benchmarks should be ran again with CSAA and EQAA used, but then again, that would mean AMD would have to show Nvidia on top, and that's not going to happen.
So a standard 290x uses MSAA in DX, and standard 290x with mantle uses EQAA is used.... sounds like to me there's very little difference between DX and Mantle in this game but let's drop the AA quality in Mantle so it pulls ahead.
lol, bless, no it certainly is not.
Matt is correct. It add to MSAA and therefore increase IQ
http://www.geeks3d.com/20110915/amd...lity-anti-aliasing-for-radeon-hd-6900-series/
Well, it's supposed to be. This describes it pretty well: http://www.anandtech.com/show/4061/amds-radeon-hd-6970-radeon-hd-6950/10lol, bless, no it certainly is not.
Great amd and Mantle makes gamers have more and better experience again playing games.
Best framevariance in the business and you dont hear any nvidia talk about framevariance anymore they gone silent due to them cant voice their opinion...as they have a worse solution atm. Funny how that works.
Seems a 290x is the card to have yet again for new games.
superb price/performance with added Mantle godness, not sure why anyone be buying other brands really.
Myers games tends to be cpu heavy also for turns.
Assuming that's correct it's certainly fair to bench mark 4x MSAA against 4xEQAA. The EQAA should actually be doing ever so slightly more work even if you subjectively prefer MSAA.
