Anec 300 side window question?
16 Nov 2008
West Midlands
Were can i get a side window for my antec 300? as i would like to be able to see into my case.
Can anybody send me a email for a shop which does it.
im pretty sure they dont exist m8, you will need to mod it yourself or pay someone too.
if you didnt mind mesh it wudnt be hard to do all you would need is to go halfords and get some of that mech they put in bioy race cars either paint it or buy the colour you want and drill a hole in the panel jigsaw it out sand it smooth repaint the panel if necesarry and either pop rivet the mesh in or you can glue it in (better finish) but make sure u dnt use cheap ****ty pva or something
There is a online custom pc shop (no pun intended) in UK that i know off that does window installs and a variety of other modding services. Window install into a case would cost about £30, and then you have to ship your side panel it to them, the do the work and ship it back to you.
You could easily do it your self mate. Try to read up on the net about making a window mod. Plan what you want / going to do. Measure 3 times, cut once!
