Annoying pause when booting up
22 Oct 2005
Moving...
....well basically when I turn on my computer it displays the asus logo, then displays another screen to do with RAID arrays. It says something along the lines of "press ctrl + F4 to set up an RAID array". I dont have a RAID setup and dont want one. It's annoying because it pauses for a short while before loading windows. Is there anyway to get rid of this or am i just being to petty!
Should be an option in your bios to turn off the on board raid just disable it and then viola ;)
if you use your sata controller (it could be that giving the message) just remove the raid bootable part (disable it) in bios
