Annoying Problem with Zonealarm (security suite)
26 Jun 2007
London
Hi, i have a problem with zonealarm continiously accessing my hard drive every few seconds, HD light only flashes for a split second but it's definately doing something!
I've turned text logging off but it's still doing it! Seems like it's using virtual memory/swap file for something stange, i checked with the filemon app and it's definately zonealarm causing the problem!
Anyone else had this issue?
Thanks
Thanks for the link, i will try the suggestions there, if not i'll give Comodo a try.
Yes anti virus is switched off now and still doing it!
Had zonealarm for years, probably doing it on my old PC too, didn't have the luxury of a hard drive light back then!
