Hi Guys,
Last week I purchased my new PC components from OCUK and I built it all yesterday.
The spec is:
EVGA GeForce GTX 680 Superclocked 2048MB
Intel Core i5-3570K 3.40GHz (Ivybridge)
Seasonic M12II 650W '80 Plus Bronze' Modular Power Supply
Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
BitFenix Shinobi USB3.0 Gaming Case - Black
Samsung Green (MV-3V4G3DUS) 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit
I bought this machine mainly for gaming, but I may use it for work purposes a long with my Mac mini also. This would mean putting a VirtualBox with Ubuntu server on it and using quite a bit of Photoshop. This means I would want to allocate a bit or RAM to those two programs, therefore having 8GB might make things a bit tight.
So I'm planning on getting another 8GB of the same RAM (Samsung Green (MV-3V4G3DUS)) and then filling up all four slots on my board giving me 16GB which is more than enough.
At the moment I don't plan to overclock, but in the future I will, will having another 8GB affect the overclock at all? Or are there any other pitfalls (apart from a lighter wallet) to having 16GB and all four slots in use on this board/with this specific RAM?
Any help appreciated, I plan on buying this today... so hopefully you guys can respond quite fast.
Cheers!
The spec is:
Cheers!
