- 28 Mar 2007
Ive searched the forums and have a basic idea that for better quality sound, the 5.1 headsets are OK, but maybe not as good as some other headsets.
However, I'm still a little undecided on which road to go down. I'm going to be getting a new Asus Zonar soundcard D2X / D2, as my razer soundcard is a little broke and I don't like the barracuda headset either, cos its fell to bits and has NO BASE.
So. I see that the Sennheiser PC350 Pro-Gaming Headset is on offer. I could get these as they will be fine, but would a cheaper Headset and clip on mic be better.
Also I see that some of the sterio headsets only have one jack connection or what ever it is, where as my old Medusas had more.
How does this work with the Xonar having lots of holes to plug things into?
Any ideas on what the sound will be like for Gaming / Misic using an alternative to the Sennheiser PC350 Pro-Gaming Headset?
Bit long winded, but i'm looking for options and opinions from people who have this soundcard and play games
Cheers
Cheers
and I have to say the PC-350's are by far the best in terms of build / sound quality. You will hear things that you have never heard before with them. Plenty of bass etc.
