Another 'check my spec please' post
13 Apr 2006
I'm suffering from an attack of nerves before hitting the order button. Can someone sanity check this lot for me please? :)
MB-062-GI Gigabyte GA_965P_DS4 (Socket 775) PCI-Express DDR2 Motherboard (MB-062-GI)
£104.95 £104.95
MY-058-GL GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL)
£124.95 £124.95
GX-053-HT HIS ATI Radeon X1900 XT ICEQ 3 SILENT Heatpipe 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-053-HT)
£189.95 £189.95
HD-078-SE Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM (HD-078-SE)
£59.95 £59.95
HS-003-SY Scythe Ninja Plus Heatpipe CPU Cooler (Socket 478, 754, 939, 940, LGA755) (HS-003-SY)
£31.95 £31.95
CP-137-IN Intel Core 2 DUO E6400 "LGA775 Allendale" 2.13GHz (1066FSB) - OEM (CP-137-IN)
£132.95 £132.95
CA-038-LL Lian-Li PC-7 PLUS Silver Aluminium Midi-Tower Case (No PSU) (CA-038-LL)
£47.95 £47.95
CD-039-PO Pioneer DVR-111DSV 16x16 DVD±RW Dual Layer ReWriter - (Silver) OEM (CD-039-PO)
£21.95 £21.95
CA-007-TG Tagan TG430-U15 430W ATX2.01 Easycon SLi Compliant Modular Silent PSU (CA-007-TG)
£46.95 £46.95
CA-008-LL Lian Li C-01A Aluminium CD-ROM/DVD-ROM Bezel (Silver) (CA-008-LL)
£7.95 £7.95
CB-001-AK Akasa Serial ATA 45cm DAYGLO Blue Data Cable (CB-001-AK)
£2.95 £2.95
CB-058-GE Akasa Rounded Ultra ATA133/100/66 IDE UV DAY-GLO Cable (0.45m) - Blue (CB-058-GE)
£5.25 £5.25
AC-000-AC Arctic Silver 5 Thermal Compound (3.5g) (AC-000-AC)
£5.50 £5.50
Cheers!
Change the graphics card to the connect 3D x1900XT its on this week only so its cheaper. Dont why your are getting those cables as they will come supplied with the mobo. Apart from that everything looks fine.
Thanks for the quick reply! I really wanted the HIS card as it's meant to be significantly quieter than the others. Shame I didn't get the order in while it was on special offer the other day :(
I went for the rounded IDE cable for neatness, and just chucked in the matching SATA cable for if I ever get a side window for the case. Actually if it's anything like my current system it will never have the side on anyway!
I would have personally got the connect3d then bought a vf900 but I guess that does void your warranty.
Been looking at other posts and wondering if I should have specced a beefier PSU. Will 430W be enough for the stuff I have listed?
Ah great, thanks for the link :)
According to the calculator my system only adds up to 357W, so I'm not sure why I keep reading you need a 500W PSU to run a 1900XT :confused:
Its all about the 12v rail. You will probably need a certain amount of amps on the 12v rail for your 1900xt, and usually bigger PSUs have more amps on the 12v. I strongly recommend you check this before buying a new GPU or PSU.
And don't forget the 'PSU calculator' is only a guide
