Another network issue..1 pc at 1 gigabit, other at 100megabits..why?
I had a similar thing once where the fix was really wierd. I had been rebooting/shutting down and starting back up but the issue remained. As part of the troubleshooting, I turned the PC actually off at the wall for a few minutes and then back on and my NIC started behaving. Worth a try.
I'll give it a go. It does sound unusual
Just a quick update.
I have turned off and on the pc and reinstalled windows (due to going ssd raid) and the problem is resolved
Unfortunately I don't know if it was the power or the reinstall but the odd issue is fixed!
Looks like I'm pretty much done with my network setup!
Thanks chaps
Thanks chaps
More than likely a driver issue resolved by the re install tbh but glad it's fixed.
