- 11 Jul 2003
- Edinburgh
Hello,
Thinking about a new PC, my current one (now 4 years old), no longer cuts it. I plan to turn it into a secondary server running multiple VMs using XEN and stick it in the cupboard. I have a NAS, so most of my files are on that (managed by my active directory server and copied off site). I may stick in 2 silent 2TB drive locally (in RAID 1) for some confidential files I don't want synced into my company network.
I do a lot of work (photoshop, intensive excel, app development and sharepoint).
While silence is the key aspect (will sacrifice performance for it), I would like a top of the range spec.
Need some ideas for graphics card and power supply. It needs to run 4 monitors at 1920x1200 each. I'd like to get back into gaming, but that's secondary. No fixed budget, but ideally under £3600 including VAT.
Thanks,
Chris
Thanks,
Chris
Code:
OcUK Tech Labs - NZXT Phantom 410 Midi-Tower Case - Gunmetal - Noise Dampened £113.99
Asus Rampage IV Extreme Intel X79 (Socket 2011) DDR3 Motherboard £311.99
Intel Core i7-3970X 3.50GHz (Sandybridge-E) Socket LGA2011 Processor - Retail £829.99
Intel Liquid Cooling Solution CPU Cooler (Socket LGA1155/1156//1366/2011) £73.98
2x Patriot Intel Extreme Masters 32GB (4x8GB) DDR3 PC3-12800C9 1600MHz Quad Channel Kit £400.78
Samsung 512GB SSD 840 PRO SATA 6Gb/s Basic - £449.99
