Hi all,
I have built my system:
Conroe E6600 Core Duo processor
BFG 8800 GFX card
EVGA 680i MB
GeIL 2GB PC2-6400 CAS4 Dual Channel Kit 2x 1Gb ram
2 x 200Gb Raptors in Raid 0
Sythe Ninja cooler - had to modify the thing to get it to seat ok.
In my warm computer room idle temps vary between 35 to 38. If I run Intel TAT and work processors temps go to 60.
I know I need to get my FSB up, but am confused on this motherboard as the Quad FSB is at 1066.
Also When I have tried raising this and saving BIOS, when the PC re-boots I get a long BEEEEEEP and eventually the PC reboots but with stock settings. I am therefore guessing the overclock failed and the PC used default settings.
So i have tried upping the FSB and leaving my multiplier on 9, but when should I add more voltage and to what?
How do I know why the overclocking failed.
Can anyone who has a similar setup to me help me out, I really want to try and hit 3.5 or 3.6
Incidentally I tried Ntune and it worked by upping the PCI speed to 3025 and it also changed the memory speeds to 4-4-4-12. Funnily enough the FSB I think went from 297 to 397 - but that is from memory.
Please I would appreciate some of your expert knowledge !!
Regards
Ian
BFG 8800 GFX card
EVGA 680i MB
Regards
Ian
