Another problem.
25 May 2010
Hi guys, So this happened before and i posted on it but last time the HDD messed up and i did a disk check and it was ok, but today i booted up and the cpu heatsink's fans werent spinning. before this it would spin the fans for about a second then stop, then start, then stop until istopped it. When i booted up this time and got into windows it told me the overclock wasnt stable or something and it reset it to 2.93ghz and booted fine but took a while.
What could be wrong?
If the fans on the CPU block had stopped spinning the system may have set the CPU back
to its normal speeds because it was overheating.
I may be totally wrong on this but that is what i would assume first off.
It was in sleep mode and i just started it up again and it did that so i dont think it overheated as it has been sleeping all night.
I also got the HDD error AGAIN :
4
