- 29 Aug 2010
- Cornwall
Hi,
I know there have probably been more threads on this than just about anything else on OcUK, but that's just making it harder for me to find the right thread!
Basically I'm pretty new to OCing and could do with some pointers with regards to OCing this combo.
I get the FSB and multiplier stuff, but it's the voltages that really get me confused.
Are there any threads that give these settings? I've found various threads with them in but it's usually people saying they don't work.
I'm looking get get a 3.0GHz overclock for starters, something that will hopefully run cool and pretty quiet. After that I'd like to go for 3.2 and/or 3.4GHz. I'm not too fussed about 3.6GHz but if I can and it's not too hot then it'd be nice.
I'm running an ABit IP35 Pro with a Q6600 (G0) and 4GB (2 x 2GB) Corsair XMS2.
For cooling I'm using a simple WC loop consisting of XSPC X20 750 pump/res, XSPC Delta V3 CPU block and a 240mm EK CoolStream rad with 2 x 1850rpm Gentle Typhoons (@ ~1100rpm currently). With the exception of the fans, these are my spare WC parts so I know they're not great but figured they should comparable to a half decent air-cooling solution right?
It's in a CM 690 II case with the top side panel fan as an intake to try to cool the mobo (since there's not HSF to move air around that section).
I'm currently using:
Ext clock - 333
Multiplier - 9x
DRAM - 1:1.25 (DDR2-799)
CPU Core- 1.3050v
DDR2 - Auto
CPU VTT - 1.23V
MCH 1.25v - 1.29v
ICH - 1.05v
ICHIO - 1.50V
and one core keeps seeming to hang when running Prime95, it doesn't fail but it just stops. The other seem to keep going though and none of the temps seem to be an issue (CPU 49ºC, System 30ºC, PWM 66ºC).
Any pointers as to which thread I should be looking at?
Thanks.
Ext clock - 333
Multiplier - 9x
CPU Core- 1.3050v
DDR2 - Auto
CPU VTT - 1.23V
MCH 1.25v - 1.29v
ICH - 1.05v
ICHIO - 1.50V
Thanks.
