Another SCSI question...
ITR
ITR
16 Apr 2006
Tamworth
Hello.
Is it possiable to fit an Adaptec SCSI Card 39320A-R 64-bit 133 MHz PCI-X, into a std PCI slot on a DFI LP Sli-D Mother Board ?
I really hope so because i've just brought one...
Thanks in advance,
Rich.
afaik, if the pci controller supports it then it could run on a standard PCI slot, but it will run waaaay slower
Yes it will work fine although bandwidth will obviously be limited due to the 32Bit/33Mhz PCI bus :( . The super low and important RA's of 15k SCSI is hardly effected if at all on a 32Bit/33Mhz PCI bus :D
Sell Your Adaptec 39320A Card ,Get a pci e SCSI card will work perfect with your DFI LP Sli-D in the 2nd pci e slot @ 8x8 config
Lsi megaraid 320 PCI E -2e
just picked this up
Cheers for the advice lads, i'll give it a bash when i get it as i picked it up for a good price.. I did think about getting a PCIe card, But i ordered another 7800gt for Sli while i still could. I'll let ya know how it goes speed wise as i can get hold of New Segate Cheeta 15k 36gig 68pin scsi drives for £60 :D
Cheers,
Rich.
