- 30 Nov 2010
- UK
Hi,
Not sure whether to do like I normally do (small pea size blob) or follow the XSPC Raystorm manual and apply a thin layer obviously this is for their supplied TIM and not the IC Diamond I'm using. I have used the IC Diamond before and found it very stiff, so wondering if it would be best to spread a thin layer it rather than rely on the tension of the block to spread it.
